73 Nova Disc Brake Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2010, 02:15 AM
zeek55's Avatar
I was wondering if anyone can tell me if there are any differences between the 72 and the 73 Nova disc brake conversion? I would like to use the old spindles so I am wondering if the modifications are the same. Any help would be greatly appreciated. Thanks, Tom
Old 01-21-2010, 05:05 AM
poncho62's Avatar
Wiki Edits: 5
I am pretty sure they are the same until they went to front steer in about 74-75
Old 01-21-2010, 12:03 PM
The 68-74 X-body (Nova and clones), 67-69 F-body, and 64-72 A-body all use the same spindles. The steering arms are different, but they are bolt-ons.
Old 02-03-2010, 11:45 PM
Just don't use A-body steering arms on a F- or X-body. It screws up the steering geometry. Other than that, the arms are the same from drum to disc, but some are shorter than others. Shorter ones give quicker steering, but higher effort.
Old 02-04-2010, 05:32 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Check out this thread: G Body with LS1 12" brake Setup? Could be just what you're looking for?? Or your old hubs might be just what us LS brake swappers need...
Old 02-04-2010, 12:24 PM
Which is why I wrote this:
The 68-74 X-body spindles are completely different from the G-body spindles and don't interchange. X-body is rear steer, G-body is front steer. I'm not sure how this applies.
Old 02-04-2010, 01:07 PM
Rickracer's Avatar
I was referring to the way the swap was done. I am aware of the front steer-rear steer issues, but the same ideas as far as caliper mounting could possibly apply, or perhaps the drum brake hubs would work for G-body and S10 LS brake swappers. I haven't worked on an earlier Nova in quite a few years,
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
1966 nova power disc brake conversion jim cass Suspension - Brakes - Steering 2 04-26-2009 09:38 AM
rear disc brake conversion TBear Suspension - Brakes - Steering 6 02-12-2009 06:41 PM
disc brake conversion BIGBLOCKSTANG Suspension - Brakes - Steering 4 11-22-2002 06:07 AM
