'73 Olds 350 Oil in coolant no coolant in oil :(
it's an Olds 350 engine.
Doesn't smoke one bit. Runs sweet.
Got oil in the water. I've only run this engine about 300 miles since I've owned it and only found this as the upper radiator hose sprung a leak.
It's an auto so my wishful thinking points me to internal radiator leak (trans fluid) Can't really tell if the trans is seeping oil into cooling system as it leaks around the pan and on the output shaft!
There is not a single trace of water in the oil anywhere. No overheating or cooling issues, no loss of power, no smoke, no rough running. It's a pretty agressive little olds in fact!
Could this be a headgasket? Cracked head? Oil runs at higher pressure in the internal passages doesn't it?
It's greasy stuff, but brown, it doesn't give the rainbow effect oil does with water and it's lumped together. Maybe it's just one of those bottles of radiator crap someone put in?
I'm clutching at straws...
Who is very familiar with these engines?
