Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '73 Olds 350 Oil in coolant no coolant in oil :(
Old 07-27-2011, 08:49 AM
FmrStrtracer FmrStrtracer is offline
Have you flushed the cooling system?
The only path for oil into the radiator would be thru the trans cooler.
If you had a blown head gasket, cracked head or block, you would have coolant in the engine oil, not the other way around.
Drain the radiator, flush with a good coolant system cleaner, refill with straight water, drive, re-check for oil in the cooling system.
