Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '73 Olds 350 Oil in coolant no coolant in oil :(
Old 09-28-2011, 07:46 PM
DQ81 DQ81 is offline
Originally Posted by DQ81
that's what I was thinking! I'm flushing it asap and putting an external trans cooler on and checking the trans fluid today.
Put external cooler on after flushing out transmission, changing filter and put new atf in obviously.
Flushed coolant. Lower radiator hose sprung a leak today. Fixing it tomorrow. Other than that all is good again.
Internal leak in the rad, go figure.
Thanks all!
