Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 73 plymouth swap
Old 03-22-2002, 11:17 AM
Rog_Van's Avatar
Rog_Van Rog_Van is offline
New Member
Hi Chris, in 1973 the 340 Duster came stock with an 8-1/4 rearend, so you can diffently use it. Sunnit racing carries a mopar performance suregrip unit for it for around $225. You may want to change your ring & pinion at the same time depending on the ratio you have now. I'm not sure about the tranny, if it's a 727 you're good to go.
