73 Pontiac Firebird Fuel Pickup Sending Unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2003, 07:13 AM
Question 73 Pontiac Firebird Fuel Pickup Sending Unit
Gone bad in my car, can't seem to locate one in my area {Virginia Beach, Virginia] Tried local auto parts, dealerships and year one. Any help would be appreciated.
Old 01-30-2003, 08:41 AM
lookatme's Avatar
Post
i'm not certain, but arent the camaro sending units similar?
Old 02-01-2003, 04:38 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Heres GM's site you should be able to find/order one from it.
<a href="https://www.spoperformanceparts.com/" target="_blank">https://www.spoperformanceparts.com/</a>
Luv the smell of NITRO in the morning.
Old 02-05-2003, 09:39 AM
Post
I recently had a similar problem.....also had a problem spending $85 for a sender from year one or performance years. I went to the local parts store and bought a universal GM sending unit....the one with no tubes. I removed the mechanicals and wiring from my original. I then took the mechanicals and wiring from the universal and transferred it over to the original sender. I clamped it in place, then spot welded the bracket on the back of the sender to the original bracket. Then I shaped the universal rod to the same shape as my original float rod and used my original float. $15 and 30 minutes of inginuity......Problem solved.
