73 roadrunner ignition switch wiring ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 02:20 PM
ramman1500's Avatar
Last journal entry: work has been going slow but sure
i had to rebuild my steering column and found that the ignition switch( the one inside the column with wires) was cracked . i re painted all the parts and am ready to put it back together , i have a new in box switch that is pretty much identical with the exception of one wire . a single orange wirethat is beside the two red wires . it is connected to the plug and is about 8" long . my original one doesnthave this wire. all the orange wires that i see on the complete orriginal wiring harness are for lights ( such as dash and shifter ) my friend says to just tape the end and forget it , i say no, can anyone help , i really want to knowwhat this wire is for. car is a 73 roadrunner originally a small block car , column shift , standard gauges. ive re done all of that . big block , floor shift , ralley pack gauges. thanks in advance
Old 03-03-2013, 02:58 PM
A quick search found this site but I don't see the colours you are talking about. Might help to go to RockAuto and look at the switch for your car. Often they have instructions available with them. They do mention a red wire.
The Following User Says Thank You to crownver For This Useful Post:
ramman1500 (03-03-2013)
Old 03-03-2013, 05:59 PM
ramman1500's Avatar
ignition wiring help
found that the orange wire is the ashtray light .
Old 03-03-2013, 06:14 PM
Glad you got her figured out. I'm not there yet. Changing a '77 Ford pickup to an '82 Crown Vic column where all switches are on the column. Probably gonna be a nightmare trying to figure the wiring on that, but I like that kind of puzzle.
Old 03-03-2013, 09:53 PM
ramman1500's Avatar
ignition wiring question
oh no , didnt say it was all figured out . this wiring puzzle is just getting started. i converted fromcolumn shift to floor shift column , and standard gauges to ralley pack gauges . may not be as intense as your project but its bad enough. and yeah i am the same way , i like having to figure out stuff but electronics takes a little time . thanks for your help
wiring ignition switch in a 54 chevy dirtinla Electrical 1 11-29-2009 11:45 PM
ignition switch wiring fivewindowcoupe Electrical 3 01-29-2009 04:50 PM
Mustang II ignition switch wiring John Hawes Electrical 1 12-09-2008 02:18 PM
Ignition switch wiring ??? primerat Electrical 2 11-10-2005 06:09 PM
ignition switch wiring daddyj Electrical 1 02-01-2003 03:19 PM
