74 camaro vin number hidden - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2007, 07:31 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by paulo 1
Guys I will have to stretch this topic a little more.I have a situation here in Brazil with a fully restored '74 Camaro.Original 4 speed,posi- diff car.Inspections are new here,and the dmv staff refused to believe that this car does not have the number stamped anywhere,besides the dash panel.I personally disassembled the entire car my self.The underbody was completely cleaned and no numbers were found.Does anyone know if Chevrolet did it?
Old 01-07-2007, 08:09 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Not sure about the camaro
but my 79 Chev 1/2 has only the dash #
There was the glove box and door stickers---but they are no longer there.
I have had everything but the cab off of this truck and have seen no #s anywhere. This is not to say they aren't under the cab on a frame rail.
But that would not apply to the camaro----subframe is a service item, and I have never seen a # on a subframe.
Bryan
Old 01-08-2007, 02:29 PM
Perfectionist Procrastinator
Last journal entry: Moving along
Ditto what Bryan said. The only place I know of to find the VIN on my 70 Nova is the three places already mentioned: Glove box, door, and dash. The only one still legible on my car is the dash.
Old 01-10-2007, 04:48 PM
Camarofiend73's Avatar
There should be partial VIN numbers by the heater blower motor and the underside of the package tray.
Check this thread:
http://www.nastyz28.com/forum/showth...en+vin+numbers
Old 06-08-2008, 09:22 AM
rachet ralph's Avatar
vin #
i've also read that GM stamped the frame rail in the back by gas take inside of rail not sure about camaro's or novas or other F body GMs, but on other GM's it on the drivers side inside frame rail, seen pic's in the magazine showing it but not sure of F-body GM's.
Old 06-08-2008, 10:43 AM
F-body cars don't have full frames.
Old 06-08-2008, 10:53 AM
i know
i know but i've seen numbers stamped on there frame rails in the unbody rails
Old 06-08-2008, 11:43 AM
Got it. Sorry for the misunderstanding. I will say that I've seen numerous VIN derivatives hidden on all 68-up GM cars. They are often covered with undercoating, paint, or rust, but they're there. As noted above, on the firewall below the heater box and on the rear frame rails are the two places I've seen. On the full frame A-body cars, the frame stamp is usually on the top of the driver's side frame rail, on the section behind the rear axle. Again, rust and undercoating make this one tough to see, even with the body off the frame.
Old 06-08-2008, 05:38 PM
I am here Brian.I found it a few months after I posted.It is stamped on the firewall but impossible for a vehicle-inspector to check.The whole right portion of the air conditioning system would have to be removed by the firewall,including the wheel tube,exhaust manifold,heater hoses and other bits.Ideally even the right fender would have to be removed.
The VIN is along side that big rectangular opening found on GM cars.Very well hidden!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
VIN Number williw50 Body - Exterior 1 10-09-2006 06:57 PM
74 vette tail lights on 68 camaro sune Body - Exterior 1 05-06-2004 04:28 PM
74' Camaro dash layinitdown Interior 2 08-26-2003 04:06 PM
Decdoing a vin number for a 1978 Camaro redcamaro4spd Engine 2 08-06-2003 08:58 PM
