74 camaro wheel question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 07:56 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Is it possible to put 6 lug hardware on a 74 camaro font end. I'm clipping my 59 Suburban and I would like to keep the 6 lug wheels.
Old 10-23-2005, 09:57 PM
A machine shop should be able to re drill a 6 lug pattern on the Camaro rotors.........if there is enough metal on the rotor..
I know that Moser Engineering can re drill 5 lugs on a truck rotor.
Look here.....
http://www.moserengineering.com/mose...opservices.htm
Look about half way down on the right side......
DEUCE......
Camaro wheel backspacing SS1969CAM Introduce Yourself 1 12-07-2004 02:10 PM
1980 Camaro Tranny question.... Juicer Transmission - Rearend 1 08-05-2004 07:27 PM
Camaro 10-bolt 8.2 upgrade - gear question EricTopless68 Camaro Transmission - Rearend 0 02-23-2004 09:10 PM
82-92 Camaro question Camaro2Fast4u Hotrodders' Lounge 1 10-13-2003 03:11 PM
Header question for my Camaro Juicer Engine 1 10-13-2003 09:11 AM
