Hotrodders Bulletin Board
#3
4:10 not so common
3:73 most common 3:08 found in the 305 AT trucks |
#4
The lower the rear end gears(higher numerically) the higher the rpm at a given mph. If you have a tach and know the tire height one can use an online calculator to get an idea of what the rear end ratio is.
#5
My '74 has 3.42's. It was originally a 'three on the tree' 3 speed manual. One sure way is to pull the diff cover and look for the numbers on the edge of the ring gear, or do some counting. It's odd to see a 10 bolt in a '74... Are you sure of the year? You may want to count the cover bolts again. This is irrelevant to ratios, though. |
#7
Jack up one rear wheel.
Put a chalk mark on the bottom of the tire & mark the driveway at that spot. Also put a chalk mark on the driveshaft. Now rotate the tire TWO exact turns while counting how many times the driveshaff turns. A 373 ratio will make the driveshaft turn 3 & 3/4 turns. A 307 would be a little more than 3 turns, but not near 3 & 1/4 turns. |
#8
My 1978 K-1500 GMC had 3.55's from the factory, it's still got them and worked great with 31 inch tires.
Back to top |
Similar Threads for: "74 chevy C-10, RPMs seem high. rear end gear ratio?"
| TH350 or 200R-4 Trans? | rltaylor46 | Transmission - Rearend | 12 | 08-29-2007 11:47 PM |
| Rear end gear ratio change = spedo. cable gear change. help? turbo 350 | sugar ray | Transmission - Rearend | 6 | 07-18-2007 10:32 AM |
| How to identify the year of a Chevy 10 bolt rear End? | frankenvette | Transmission - Rearend | 2 | 04-07-2005 09:14 PM |
| Help with '57 Chevy Rear End | 57Chevyman | Transmission - Rearend | 15 | 12-25-2003 08:43 PM |
| 1972 Olds rear end gear ratio | jpd37 | Transmission - Rearend | 4 | 09-26-2003 02:59 PM |
