Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 74 chevy c10 ignitiont no power PLEASE HELP!
Old 10-30-2012, 04:28 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Sounds to me you have a loose connection somewhere....When you stomped your foot on the floor and it fixed it, you likely made the connection. First thing I would check is the back of the fuse box where all the wires come through the firewall....In the middle of the block on the firewall side is a bolt that holds the 2 sides together. See if that bolt is tight.
