'74 Ford Courier 1.8 L. Discharge when Lights are on. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2006, 08:10 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
I Reciently Replaced the Head Lights With Normal U.S. "Bulbs" - Had Neon / Halagon Or ??? Has A New Alt. Form the Book: I Cant find the Same Voltage Regulator, Replacement! I Want an Adjustable V. R. The Guage is Maxed at 30 A's.Recomendations From the Alt. Maker was to Replace the V.R. When Replacing the Alt.
Old 12-19-2006, 04:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here
Check all your grounds.
Run a properly gauged Ground cable from the battery to any handy bolt at or near the starter, From that same Block bolt get a Battery cable at the parts store, that has two 3/8 ring terminals on each end and attach it there and to the Frame.
Next get some 10 gauge wire and ring terminals and run that from your Block bolt on the block to the Firewall, and another Separate wire to the Alternator bracket, Lug or mount bolt.
Next get some Wire Braid, (Radio Shack) and install braid from the radiator support to the frame, Fenderwells to frame , hood to firewall, Doors to door posts, gas flap to body, tailgate / Trunk to body.
At each point the wire is grounded, Burnish ALL the paint and grease off to bare metal. Use a proper star-washer and lock. Use sheetmetal or Tech screws where no screws are available.
It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 12-19-2006, 08:30 PM
That is Good Advice -- No Ground = No Juce.
I Don't Want to Rewire the Entire Charging System. And Probably Can't. The Looms are needed.
Old 12-26-2006, 01:06 AM
'74 Courier Charging...
Well... I Feel like I'm At the Suers level, of Wisdom!
I spent 6 Hrs trying to find a Voltage Regulater! 1/4 Tank of Gas!
ALL TO PUT THE OLD V.R. BACK ON, & TIGHTEN THE BELT!
(Now works Perfect.)
74 Ford 2bbl carb...Help ASAP please! 59Fairlane Engine 4 02-06-2006 05:34 AM
Ford Courier pickup sway bar for hot rods willys36@aol.com Suspension - Brakes - Steering 1 05-03-2003 09:07 PM
'74 Ford Electical System mystical_magickal_one Electrical 0 04-24-2003 10:16 AM
74 Ford 4 Speed Manual... 59Fairlane Transmission - Rearend 2 12-30-2002 10:34 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
