74 javelin rust problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2003, 09:36 PM
New Member
Post 74 javelin rust problem
i've got a 74 amc javelin and on the back quarter panel right behind the tire there is a hole from where it rusted through. So which way is best to fix this. To use sheet metal or use fiberglass to fix the hole.
Old 04-07-2003, 09:40 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Sheetmetal is and always will be the best answer and correct way. Check the Knowledge base if you need help on bodywork or patch panels.
HK
