74 Monte Carlo - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2002, 06:01 PM
Post 74 Monte Carlo
I want to build a pro street car using a "74" Monte Carlo. Is this an "A-Body" or "G-Body" ?
It currently has a GM 10 Bolt rearend. If I am looking for a 12 bolt, what other cars use the same rearend configuration. Is there a way I can build the 10 bolt to be used with a 500 HP big Block engine? Thanks For your help
Old 02-25-2002, 11:14 PM
New Member
Post
I think if your going for that much HP, you might want to look into a Dana60, or something like that.That's a lot of HP to put to the ground through a 10 bolt, or even a 12 bolt for that matter.If your going for prostreet, width won't matter, and any 12bolt will work, the mounts and shock mount and width will have to be changed anyway.You might even concider a ford 9 inch, the drop out third member makes gear change a breeze.But again it is pretty lightwieght for that much horsepower.
