Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 74 nova 350 into a 74 buick apollo,
Old 10-03-2012, 08:18 PM
Dohertytl Dohertytl is offline
Hey every one first time here, I need a little advise about and engine swap im doing, I m try to drop a 1974 nova 350 into my 1974 buick Apollo and Im running into a little problem with the mounting I assumed the mounts where the same as they where both GMC of the same year and the apollo is basically a nova clone but as I found this is not the case, Im thinking that if I put nova engine mounts on the frame (asumming they will bolt up) It would be a quick fix but Im not sure what type of mounts I should get ( this is my first engine swap) also I think the nova engine and buick trans will bolt up with an adapter plate but that also might be wishful thinking, anyways any help info or tips would be great
