74 nova 350 into a 74 buick apollo, - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2012, 09:18 PM
Hey every one first time here, I need a little advise about and engine swap im doing, I m try to drop a 1974 nova 350 into my 1974 buick Apollo and Im running into a little problem with the mounting I assumed the mounts where the same as they where both GMC of the same year and the apollo is basically a nova clone but as I found this is not the case, Im thinking that if I put nova engine mounts on the frame (asumming they will bolt up) It would be a quick fix but Im not sure what type of mounts I should get ( this is my first engine swap) also I think the nova engine and buick trans will bolt up with an adapter plate but that also might be wishful thinking, anyways any help info or tips would be great
Old 10-03-2012, 09:40 PM
BOBCRMAN@aol.com's Avatar
Use 74 Nova frame and engine mounts. Adapter will work on trans. Should be fairly straight forward swap. Many similar have been done.
Old 10-03-2012, 11:04 PM
there is a possibility that the engine is a 75 would that change anything?
Old 10-04-2012, 07:41 AM
No, all SBC mount bosses are the same since 1958.
74 buick apollo, 74 nova 350, engine swap
1973 buick apollo 350 ljrsports Engine 8 09-23-2012 05:06 PM
68 nova project is a buick 430 worthwhile? Dre68chevyII Hotrodding Basics 7 10-01-2010 01:30 PM
First swap- 75 Nova & 350 Buick motor neonova75 Hotrodding Basics 11 10-17-2009 08:27 PM
will a nova sub fit my 31 buick? lostinthought Hotrodding Basics 7 12-21-2005 07:08 PM
1974 buick apollo sjsurfr Hotrodders' Lounge 0 04-18-2004 01:47 PM
