74 Nova brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2003, 06:06 PM
Post 74 Nova brake swap
I want to put front disc brakes on my nova without a huge cash outlay where am I going to find a decent bolt on for this? thanks
Old 01-17-2003, 07:25 PM
BOBCRMAN@aol.com's Avatar
Post
the only real bolt on for this is nova 68-on or 67-69 Camaro. the only real spindle difference is the top bolt boss on the spindle (holds the backing plate) is longer than the disc brake spindle and you can trim it down and rethread it, then the disc brake parts will bolt on.
Old 01-18-2003, 01:37 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Smile
Go to page #2 about half way down on 68-72 nova disc brakes,as stated find one of these donor cars,will work ,you can use drum spindle,the top boss that the dust plate bolts to cut off 1/2 inch
