74 nova rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2006, 09:15 PM
75sprintguy's Avatar
Last journal entry: a good used 350 we installed
74 nova rear
would any one know the ratio in my factory 74 nova rear end its a 6cyl car 350th trans just wondering cause im transplanting a 350 in it this week end.i heard since its a 6 banger it could be pretty low geared i hope so
Old 05-02-2006, 09:36 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
anywhere from 2.56 to 4.11. It probably has a 2.73 or a 3.08. those were very common for 6 cyl cars. If yo can get the axle code on the passanger side facing forward i can give you what was in there from the factory. the only real way to see whats in there now is to pull the cover.
Old 05-03-2006, 10:15 PM
http://novaresource.org/axle.htm says 3.08 came standard with the 6. Codes can be found there, also. Like 1969NovaSS said, somebody could have changed something since 1974.
If you pull off the rear cover, look around the edge of the ring gear until you find a series of numbers, usually 4 numbers total. Might be a 7-digit part number, also. Two of the numbers will be the tooth counts of the ring & pinion gears, and the other two will be the date of manufacture. For example, say you see 40 13 12 73. The "40 13" will be the tooth counts, the larger of which you divide by the smaller to get your gear ratio (40/13=3.0769 or 3.08). The "12 73" means the gear set was manufactured in December, 1973. Etc., etc., etc.
looking for dash panel & gauges for 74 nova owsballa Interior 2 01-29-2006 06:26 PM
63 Nova Front & Rear Seats Mustangsaly Interior 3 10-13-2005 09:44 AM
will nova rear end fit in 67 firebird? red_rider52 Transmission - Rearend 9 01-19-2005 10:52 PM
pulling transmission out of 74 nova CombatWombat Transmission - Rearend 5 04-25-2004 01:04 PM
Nova rear end sb72elcamino350 Transmission - Rearend 4 11-22-2003 03:34 AM
