740P pistons for a sbc 307 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-28-2011, 09:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 72chevyBuild
Since my compression will be close to 10:1 do I need to change my converter?
You are quite a bit short of 10:1. In any event, I'd use the 260H over the 268H.
  #17 (permalink)
Old 12-28-2011, 09:55 PM
Why? Cause of the duration difference?
  #18 (permalink)
Old 12-29-2011, 02:34 PM
BigEd36's Avatar
The 260H, with shorter duration, will have better torque and responsiveness at take-off and low speed driving with a stock torque converter and hiway gearing. Comp Cams shows an RPM operating range of 1200-5200 rpm for the 260H and 1500-5500 rpm for the 268H, so the 260H brings on the bottom end at a lower rpm, basically right off of a fast idle speed.
  #19 (permalink)
Old 12-29-2011, 03:44 PM
I like the 260H, i had one on my 283 SB with 305 HO heads and a holley intake and that motor ran strong. But i am running camel hump heads and a stock intake, i just want a good cam to run with that.
trw pistons winged47 Engine 6 11-09-2012 03:59 PM
Used pistons? weirdbeard Engine 5 12-10-2008 11:01 PM
pistons jerry1 Engine 5 12-14-2006 10:19 AM
pistons cadallac Engine 0 01-28-2004 09:16 AM
pistons 78 chevy truck Engine 29 01-26-2004 10:34 AM
