Thread Tools Search this Thread share on Facebook
  #1
Old 12-21-2011, 06:33 PM
72chevyBuild 72chevyBuild is offline
740P pistons for a sbc 307
I was taking apart my chevy 307 the guy I bought it fron said it was 30 over but then the piston where not stamped so I had a .040 piston from a 283 an of course the share the same piston size but the 307 piston is bigger so now the only number I found was 740P feb 92 can some one help me
Register now (free) or login to remove ads
Old 12-21-2011, 07:51 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last journal entry: Fresh paint
Wiki Edits: 9
Your post is very confusing, and a run-on sentence/post. I don't know what your reference to the .040 piston thing is, or the 283 piston. You know they have different strokes, right? Can you explain?
I don't believe the 283 and 307 share the same piston, they're different strokes and different compression height (pin location) pistons.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 12-21-2011, 08:42 PM
Well I was told that a 307 shared the same bore as a 283. And the motor was suppose to be .030 over and the piston I tried was from a 283 bored .040 over but the pistons are not marked or stamped but I did fine a 740P on the inside of the piston
Old 12-21-2011, 08:45 PM
So I am trying to find out what 740P means?
Old 12-21-2011, 09:25 PM
68NovaSS's Avatar
Wiki Edits: 9
The do share the same bore, but not the same stroke. The 283 stroke is 3.00", the 307 is 3.25".
I'll give you a start in your search, the 740P piston was manufactured by Ohio Piston & Pin, now out of business, and sold under the brand names Nytel and Ertel. They were once associated with Dynagear, but not sure in what capacity.
Maybe some here from back in the day can shed more light.
Old 12-21-2011, 09:57 PM
Yeah the 307 has the stroke of a 327 but the bore of a 283. But I'm just wondering what size it is, I am thinking probably .060 over. Thanks for the info
Old 12-26-2011, 03:59 PM
Just found out my 307 is bored to a standard size 327. Planning on running camel hump heads and a small mild cam around a 210 or 212 duration. Anyone got some opinions on that? I would like more help on my build
Old 12-26-2011, 10:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Makes sense- the 740P is a 327 SBC slug. So your 307 is now a 327.
Nothing wrong w/that cam duration and cylinder head- keep the quench tight, the CR might be a bit low, but w/a short cam that's OK. Might want to run the dynamic CR numbers just to be sure you're in pump gas territory.
Long tube 1-5/8" headers, a dual plane intake and a Q-jet would make a pretty sweet street engine.
Old 12-27-2011, 08:12 AM
Yeah I think my cr would be around 9.5 or 9.75 to 1 but I also have a 260h cam I am thinking about using? What do you think?
Old 12-27-2011, 05:30 PM
the cam i have is like a 204 to 208 duration not a 210 or 212.
Old 12-27-2011, 11:26 PM
BigEd36's Avatar
BigEd36 BigEd36 is online now
According to the Badger Pistons website:
History:
July 2008 – Badger Pistons, LLC relocated its operation and warehouse to Bedford Park, Illinois.
May 2006 - Badger Pistons, LLC relocated its manufacturing operation and main warehouse from New Albany, Mississippi to Marinette, Wisconsin.
February 2003 - Badger Pistons, LLC was formed with the acquisition of the piston manufacturing plant and the remaining piston inventory of Dynagear Corporation.
1998 - Dynagear Corporation acquired Ertel Manufacturing Company. Shortly thereafter, all piston production was consolidated at the New Albany, Mississippi location.
I have to wonder whether 72chevy's engine is in fact an original 327 or a 307 overbored .125". Can a 307 be safely bored .125"? No matter, if it's using a 740P piston it must be a 327. If it is in fact an original 307 with a .125" overbore I would be very leary of doing any further overbore for this build.
Cobalt327 made a good suggestion to run the compression ratio figures. I ran the compression ratio using 4" bore, 3.25" stroke, 5.7" rod, standard .025" deck height, a .015" thick by 4.1" bore head gasket (Fel Pro #1094), 7cc for piston dish (flat top with 4 valve reliefs), and 64cc heads (the double hump heads). I got a static compression ratio of 9.43. Using the specs for a Comp Cams 260H I got a dynamic CR of 7.99 so your build is well within range for pump gas use.
Ed
Old 12-28-2011, 08:34 AM
No I am not going to do any more bore to it. But the casting numbers on the block are infact a 307 from 1969. But I am still deciding to use the 260H cam or the 268H cam still undecided.
Old 12-28-2011, 11:02 AM
Since my compression will be close to 10:1 do I need to change my converter?
Old 12-28-2011, 05:57 PM
BigEd36's Avatar
With the 268H your dynamic CR will drop slightly to 7.78. Comp Cams literature shows the 270H as "Biggest cam with stock converter but better with 2000+ stall" so both the 260H and 268H are mild enough to work well with a stock converter, but both would show increased performance with a slightly higher than stock converter. On Comp Cams free simulator software, CamQuest.com, the recommended TC for the 260H in a 327 is 1500-2500 rpm. The recommended TC for the 268H in a 327 is 2000-3000 rpm.
Old 12-28-2011, 06:01 PM
thanks for the info i feel better with using the 268H cam without changing my converter.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "740P pistons for a sbc 307"
ThreadThread StarterForumRepliesLast Post
trw pistonswinged47Engine312-30-2008 12:48 PM
Used pistons?weirdbeardEngine512-10-2008 11:01 PM
pistonsjerry1Engine512-14-2006 10:19 AM
pistonscadallacEngine001-28-2004 09:16 AM
pistons78 chevy truckEngine2901-26-2004 10:34 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
