75' 350 : Edelbrock tall valve covers and A/C Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 08:52 AM
Hi everyone! a friend of mine has this 1975 Camaro with a 350
that has Edelbrock tall valve covers on it.-
He loves the covers but he wants to reinstall the AC.-
What can we do ? Is there some adapter bracket or some mod or trick to make them both covers and a/c fit?
thanks !
Old 04-18-2009, 05:09 PM
75gmck25's Avatar
I assume the stock system used the A6 compressor and the large bracket that goes over the valve cover to hold the back of the A/C compressor.
For my '75 GMC (350 with stock air) I switched to a Seltec compressor and one-piece bracket that I bought from Arizona Mobile Air. The bracket is made out of aluminum and it bolts only on to the front of the engine. There is no bracket over the valve cover. The bracket assembly was not listed online, but they were able to order it over the phone. The only disadvantage it is that the new setup needs an even longer A/C belt than the A6, so it included an idler pulley for the A/C belt.
I also switched to a parallel flow condenser at the same time, so I had a complete set of barrier hoses made by a local shop.
Bruce
Oldsmobile 350 to 455 A/C Pulley Swap dbs16 Engine 0 03-13-2009 11:47 PM
Overheating and a/c question.. Meangreen General Rodding Tech 28 06-23-2004 10:02 PM
on sbc will tall valve covers hit A/C? bullheimer Engine 4 05-26-2004 12:30 PM
BBC tall valve covers Sub_Urban_454 Engine 11 10-25-2003 06:54 PM
A/C question Paco Engine 1 06-03-2002 07:01 PM
