Front or rear steer is the first thing you look for. What is yours?
Hey Thanks , It looks like a front steer and they have a bunch of spacer Jammed into the coil springs ???...What a mess !!!! The front sway-bar is detached and the rear end is lowered to much and bottoms out on the slightest little bump.( one leaf spring ???? ) I'm thinking of pulling the entire body off and doing it the correct way from the ground-up , but I don't have the garage space to take on that size of a project . - so I guess I'll be doing little corrections one-by-one.. Right now I'm working on putting a fuse box in and straightening out the wire mess .. there isn't a single fuse on this truck ! not even the radio !
