75 Chevy Parking Brake Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 05:54 PM
david-b's Avatar
Dave is THAT guy
Quick question, been searching online and through the books and not finding the answer. I've got the parking brake on my 75 Monte Carlo just chilling nearly on the ground. The cable comes from the pedal, and then splits up going to the back brakes. I get that the cable needs to be mounted somewhere, but not seeing where it goes. How does it mount?
Thanks
Old 11-17-2010, 05:26 PM
i havent done much work on montes, but on all my pickups there are little steel rods with a hook and a loop that hold the cable close to the frame then it runs into the drum
Old 11-17-2010, 08:19 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
on my 66 Elky
the front cable goes thru a hole in the frame and then up to the pedal.
this cable should have a "U" loop on the end for the intermediate cable.
the intermediate cable comes to the front from the rear and on the passenger side there is an "S" hook that hooks into the trans X-member.
That is the only support under the car for the intermediate cable.
The cable is held suspended by that "S" hook and the "U" loop.
It is adjustable at the "U" loop
The rear cables are supported at the drum and at the frame near the rear control arm.
You may have lost the "S" hook in the trans X-member, and that will make it
sag big time.
Monte Carlo----Chevelle on steroids
Chevy II Front Brake Conversion problem Trevor Horn Suspension - Brakes - Steering 5 04-05-2007 08:10 PM
Brake Lines for 1968 Chevy SWB 68chevytrkr Suspension - Brakes - Steering 2 10-03-2006 02:34 PM
Parking brake cable removal ... TaskForce55 Suspension - Brakes - Steering 4 09-13-2006 10:30 AM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 12:47 AM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
