ok heres what i got po took all the powersteering stuff out before i got the car its got the pont 400 factory 80A alt but i got no brackets to mount up the pump ive try'd seaching the net to see if there diff from the comon pump brackets but cant seem to find much info on the 80A set up if any 1 has a good link or pic's would help out alot
I think the difference wouldnt be the PS brackets but more likely the spacer for the alternator pivot point wich is also the pivot for the ps pump.
I looked at the 1973 ps pump and brackets I have and that is what Ithink. I could post a pic. Do you have a pic of what you have?
the brackets for the alt has 1 looks like a big c its biger then the 65A bracket. the other is aluminum the only thing that looks to mount to it is the alt an uses 3 bolts in line to the head.i have the 65A set up for the pump but it wont line up with the 80A stuff
Maybe you could go back to the stuff that all worked together and run the small frame 65 amp. If you need more juice, those can be rebuilt to make 100 amps.
Here are a few pics. Not sure what aluminum bracket you mean.I dont think the alternators are anything over 63 amp, but I like pictures, they help keep it real.
I think the first pic is a better representation of the setup. The second is too old as I think it is a 65 , the first is a 73
main reason i wanted to keep the stock set up is the po just replaced the 100A alt couple weeks before i got the car
an the aluminum bracket it mounts to the head the lower mounting point of the alt has 2 tabs 1 with just a hole the other a sleave ill see if i can find a pic of that mount on ebay
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
