75 firebird question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 11:36 PM
87fubar's Avatar
i just got done putin these headers on my pont 400/4speed the driver side went on nice no problems but i go to put the pass side on lower'd the motor back down an the header is so close to the crossmember couldnt slide a pieace of paper under the header idk if i want to try an drive it that way i did replace all mounts with new could i have goten the wrong motor mounts or could it be my frames bent
Old 04-27-2011, 11:44 PM
What brand of header? The cheaper they are, the worse they fit, sometimes needing clearencing(hammer).
Old 04-27-2011, 11:57 PM
87fubar's Avatar
not shure on brand but there build better then the hooker supercomps i got for a 67 firebird.the other thing i noticed is the fan shroud if it still had the factory style clutch fan it would sit way to low an hit the shroud
should i try poly mounts
Old 04-28-2011, 02:41 AM
Poly mounts wont help if you get the wrong ones. Find out why/how the motor has dropped( wrong mounts,or the body/frame bushings are bad).
Old 04-28-2011, 05:54 AM
87fubar's Avatar
the mounts i got were those anchor brand replacements the motor seems closer to the crossmember on pass side driver side same shape on the header is about an inch from crossmember so idk how i should go about this
Old 04-28-2011, 06:34 AM
87fubar's Avatar
the core support mounts dont look to healthy just went looked but rest looked to be new
found my part numbers for the mounts if that help's at all
anchor motor mount #2387
duralast motor mount #2387
anchor trans mount#2288
Old 04-28-2011, 06:50 PM
87fubar's Avatar
just took tape to it the pass side sits 1/4 of an inch lower then driver side went by same point on both sides the front header tubes are same length from the flange to outside of the tube tube in this area what should i check
Old 04-28-2011, 09:12 PM
87fubar's Avatar
went an mest with it some today the driver side mount the inner part has shifted against the top outer edge of the shell. i can move the inner part around with my hand with the motor not siting on it. i try'd to put it in middle of its shell an hold the other side of the motor up it went right back to its spot like it was before i started. the pass side is in the middle of its shell
'68 Firebird question: Thinking Man Suspension - Brakes - Steering 5 06-30-2007 10:25 AM
One more 79' firebird question?? Rough-Rider Engine 3 02-12-2007 02:07 PM
68 Firebird AC Question SouthernRodder General Rodding Tech 3 05-31-2006 11:51 PM
69 firebird brake question fletch69 Suspension - Brakes - Steering 5 08-03-2003 01:35 PM
89' Firebird Trans Question tminnie Transmission - Rearend 1 10-29-2002 02:43 AM
