Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 75 Monte Rear End
Old 09-20-2011, 10:43 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
It can be done by a 1st timer but, can be quite a tedious job if you've never done it. Also requires a few special tools and close tolerance precision work.
Look thru these links & see if you want to try & tackle it, if not let a Shop do the work
Some very good Gear Swap Info:
http://www.hotrod.com/techarticles/d...install_guide/
http://www.thirdgen.org/techboard/tr...axle-gear.html
http://www.yukongear.com/Downloads/M...structions.pdf
