Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 75 TA fuel gauge doesn't work
Old 07-21-2012, 03:48 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Normally any gauge has to have 12v+ to one side marked with a + or i for ignition , and S which is for the sender and a circuit for the illumination of the gauge connected to interior light circuit. The easiest way to check back through the wiring for power loss is with a simple 12 v pen. Its sharp enough to probe the wiring. You can dab superglue where you puncture the insulation on the wire.
Al
Name:	Fuel gauge diagram.jpeg
ID:	66904   Click image for larger version
Name:	12 volt tester.jpeg
