750 Cfm Afb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2006, 02:22 PM
Last journal entry: hot rod axle
750 Cfm Afb?
Hey guys,
I just scored a 1410 Edelbrock AFB nearly new in the box way cheap. 750 CFMs of big throat AFB!! The guy I got it from was convinced that it wouldn't work for automotive applications.
So what's the difference? It has a choke, it has vacuum from the air horn. What I don't see is vacuum from the throttle plate. Is that the only difference?
I can get vacuum from the intake manifold, if I need it.
Anybody up to speed on the difference between marine and automotive applications?
Old 10-26-2006, 05:19 PM
DOUBLEDICK's Avatar
In my Edelbrock owners manual it shows that it is jetted the same as the 1412 &1413 which is the performer eps 800 cfm but it is 750 cfm. Change the jets to.110 main and .107 secondary and use the 1459(075x047) metering rods to make it jetted the same as automotive 750.and you can use manifold vacuum for the distributer.This chart out of the manual should help you dial it in for your application
Name:	Picture (436 x 600).jpg
Old 10-26-2006, 05:25 PM
Wow!!
Doubledick!!
Thanks!! that's probably more information than I would have gotten if I called Edelbrock!! I may keep the 600 that's on the 454 tho, as I balloon foot around like an old grandma, and the 600 works fine IF I Don't GET CRazY! Thanks again.....M
Old 10-26-2006, 05:28 PM
DOUBLEDICK's Avatar
My 427 runs a little lean at lower altitudes I would say the 750 was a better choice for your 454 than the 600 I get 14 mpg at 70 with my 500 + hp engine and 4.56 gears
Method to determine carburator CFM? jpd37 Engine 68 10-29-2006 09:55 AM
VE, CFM from Injector Flow & RPM NXS Engine 0 07-03-2005 02:11 PM
750 cfm secondary vacuum enough for a blown engine? 84Z Engine 36 09-20-2004 10:33 PM
750 cfm carb - tuning - smaller jets or 600cfm? 65truck Engine 8 01-20-2004 06:13 PM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 06:25 PM
