Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 750 double pumper or vacuum secondary
Old 11-12-2010, 09:00 AM
kleen56's Avatar
kleen56 kleen56 is offline
It's a matter of preference. I personally like the double pumper carbs because they come on when you want them to. Vacuum secondaries are OK but there's nothing better than depressing the pedal and manually giving the engine that squirt of fuel. I also run low gears which helps with carb performance. It's hard to recommend a carb because everyone has their opinions. Just like this one
