750 double pumper or vacuum secondary - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-15-2010, 10:24 AM
scapegoat's Avatar
I recently had a huge off idle stumble with my carbed 6.0 Ls engine. The only thing that worked for me was going to a 50cc accelerator pump with a #40 squirter. I also run a .570 lift .228 @50 duration cam. And very large intake runners on my heads "260cc". So I was not getting much velocity off idle. Zero stumble now.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Holley Carb Vacuum Secondary Help leejoy Engine 13 05-10-2006 07:40 PM
vac secondary carb or double pump??? maddmaxx Engine 10 11-01-2003 01:53 PM
carb Joe_Alan216 Engine 5 06-28-2002 06:59 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
