750 holley carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 08:26 AM
750 holley carb
i was told that a 750 holleywas to big for a small block and was told to lower to 1 600 or 650 is this correct
Old 04-19-2010, 08:39 AM
lg1969's Avatar
Google "Tunnel Ram 406"
It depends which 750 holley you are using, 750DP or 750VS, and wish small block you are putting in. Is it heavy car or light car, type of tranny and rear end. All this you have to take for the account for the right combination. I used a 750VS on my 307 and ran fine.
Old 04-19-2010, 08:43 AM
its a heavy car with no posy trac and its a 3310 with sec vac
Old 04-19-2010, 08:50 AM
350 small block
Old 04-19-2010, 09:08 AM
lg1969's Avatar
Nothing wrong using a 750VS on a 350. It's fine. Just be sure the intake manifold is high rise and square bore type bolt pattern.
Be aware there are two version of 3310 780 an 750. 780 has a sec. metering block and 750 uses metering plate. The one with the metering plate is prefered carb for your use. 780 is will work fine. Not as responsive like the 750.
Old 04-19-2010, 09:52 AM
im not very familiar with carbs at all i can replace anything but wouldnt know how to tune them this is my first hotrod i do know it has sec vac but thats it so you think its ok to run it or would it be better to switch to a 600 or 650 performance wise
Old 04-19-2010, 09:54 AM
and it does have a metering plate
Old 04-19-2010, 10:02 AM
lg1969's Avatar
600VS will do great. Not 600DP or 650DP. I was you I will put the carb you got. BTW: the carb you got is a 750. If the car feel sluggish or hesitates then a 600VS will be better off. It no big deal tunning a carb.
Old 04-19-2010, 10:08 AM
any pointers on tunning a carb
Old 04-19-2010, 10:14 AM
lg1969's Avatar
No different adjusting a 2 barrel or 4 barrel. Just make sure the timing is set properly, then adjust it for the best idle. Good luck
Old 04-19-2010, 10:15 AM
thanke you for the help
Old 04-19-2010, 03:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
Holley 750 vac sec Carb onecoomofo Engine 6 05-02-2004 04:54 PM
770 Holley street avenger or 750 BG Street Demon Shawn Horan Engine 8 04-03-2004 08:23 AM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
750 holley carb. wayne creel Engine 2 01-02-2003 06:40 PM
