'76 460 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 04:31 PM
Last journal entry: 69 Mustang
'76 460
I have a 460 out of a '76 Lincoln. Ive been told that the manifolds were not that great and if I could, maybe try to find a set of Interceptors. Also, I may want to get another timing set. Does anyone know whether the heads that came on this engine or any good, or would an upgrade be recommended? I know I need to go with an aftermarket intake, just not sure about the heads.
Old 08-10-2010, 02:28 AM
aka Duke of URL
If you can find a set of P.I. exhaust manifolds, they may be pretty pricey. A set of shorties will probably be cheaper.
68-71 HI-COMP
72 JUNK
73- LOW COMP
-460 CYLINDER HEADS COMPARISONS-
Old 08-10-2010, 03:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the timing set is OE or an OE-type replacement, it will be the retarded variety. Not what you want for performance.
Depending on what the engine is going into, there are 429/460 long tube headers that fit everything from Mustang/Capri's to F350 trucks- unless you want/need to keep cast iron manifolds.
Old 08-10-2010, 07:19 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Ditto, as a rule, shorties are much ado about not much at all, a waste of time and effort. If you want performance, you want long tubes.
Old 08-10-2010, 07:48 AM
Thanks for the info.
460 build for mpg vogey Hotrodding Basics 11 06-27-2013 07:20 PM
Ford 460 ci carb questions HELP ME!! RampedUpMobile Engine 5 04-09-2010 11:20 AM
All Aluminum 460 Block thunderbird87 Engine 14 06-01-2007 08:28 PM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 07:15 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 12:51 PM
