76 caddy to air ride??? school me. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2013, 08:35 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey.
i may just end up pickin up that ole 76 caddy. I have an airbagit full suspension kit that i bought for a totally different project.
Dont know a ton about it but it cost me decent green....has 1/2 inch lines....a digital box that works seperate settings and is a complete kit. Lol
can you use these kits for basically any car? Or will it bein a caddy will i have to buy special bags or adaptors for it?
i want the caddy to be able to almost drag the ground.
Ill get my exact kit number but wat kinda mods do you need to do so yer car will almost drag the ground? Is the kits pretty much easy or are there lots of fabbing? Tnx...HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-26-2013, 07:53 AM
Wiki Edits: 27
Gm engineering,
Most of the GM chassis engineering was done by the same
guys, Find a bagged Chevy and look it over carefully and see what you will have to modify. I have modified a truck kit to fit a different year, I make different brackets. I got a rear kit , unused for $ 150. so it was worth my time.
Old 01-26-2013, 12:42 PM
Thanks.
i saw a guy doing a air ride change on a caddy and he had the replacement struts with wat looked like built in bags.
Just wondered if those were wat i had to use or is it just an option.
I have like a 1200 kit from airbagit.com that has all the 1/2 inch lines.....tank...switches...bags and a computer setup. Just wondered if it will work on it??? RR
Old 01-27-2013, 10:15 AM
Is the Caddy an Eldo or a RWD? The Eldo uses a torsion bar front suspension to clear the front driveshafts and adapting an air suspension will be a lot more work than for a RWD car.
Old 02-13-2013, 06:49 PM
Just call Airbagit and ask them, they will be able to tell you if your kit is strong enough for the weight of your car, if it is just a matter of swapping a few adapters...
Old 02-16-2013, 02:19 PM
if your callin airbagit talk to Joy shes pretty nice and seems to know her stuff 1-800-842-8789 i kinda baffeld her about baggin a i beam ford but went out and talked to the guys in the shop and called me right back. great service two thumbs up
Old 02-16-2013, 06:12 PM
302 Z28's Avatar
There are air bag suspensions then there is RideTech.
Vince
Old 02-21-2013, 12:14 PM
I may be able to help you here. your Air bag it kit.. is i personally feel the biggest problem you have. I've been doing air ride for the better part of 15 years. ( i know that means nothing on the web lol) but I've never had a quality product from AIM aka airbagit.com your probably going to be much happier with a kit consisting of quality built parts. i only sell and install parts from major name companies.
Sell your AIM kit and put that money towards better parts and you should be able to install the air ride and never touch it for years.
My Malibu has been bagged for 10 years. I've only replaced the compressors. and i just did that. If you have any questions feel free to PM me and ill give you my number i can answer any questions you have over the phone and well get your caddy down where it belongs.
Air Ride, but not for your normal ride... MiniMiniTrucker Suspension - Brakes - Steering 35 03-30-2009 02:30 AM
air bagging my 58 caddy atotalnincompoop Suspension - Brakes - Steering 4 03-14-2009 10:27 AM
Air Ride on a 1953 chevy bel air LowClearanceCustoms Suspension - Brakes - Steering 1 10-16-2008 03:40 PM
Old School Air Cleaners! Abomination Engine 10 09-24-2007 08:24 PM
Air Ride/ Air bags spikes_50 Suspension - Brakes - Steering 4 11-07-2005 01:08 AM
