Hey there,
I need some one with more experience than I.
I want to pick up this brand new set of spindles, rotors,
loaded calipers, hoses etc.. complete from a 74 Camaro.
I am pretty darn sure they will go on my 65 Chevelle. I need
a second doctors opinion. Hole for the ball joint, location angle of
where tie rod bolts up to spindle, etc...you know what I mean.
A direct bolt on.
Thank you in advance I appreciate it.
wont work .you need disc brake parts from 72 or older a body such as monte carlo chevelle skylark cutlas lemans .i have several 65 malibus and have experienced the same dilema you are having on disc brake swap
Hey there,
A direct bolt on.
Hey thanks for the tip. So I need to keep an eye out for 64-72
A-body front set-up? That will be a direct bolt on swap?????
Billyjack, you said you have a lot of 65 Chevelles. Do you have a
SS gauge dash, not idiot lights? Also looking for a back seat complete.
depending on where you are I will pay for shipping. I am in Washington
State NW.
thanks
State NW.
thanks
64-72 A-body (though factory disks were only offered for 67-72), 67-96 F-body, or 68-74 X-body all use the same spindles and will interchange. The F-body and X-body cars use different steering arms, but these bolt on, so just swap your originals onto the spindles.
you can make 70 and up f body spindles work but you run into a lot of differences . ball joint size bump steer spindle height intergraded contol arm lots of design changes on f bodys the newer you get . i always try to stick with what i know will work . there are alot of supliers out there that offer direct bolt ons .original parts group is an exellent source for chevelle restoration parts www.opgi.com or www.yearone.com i have used both companys or you can find some of the parts at some junk yards
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
