76 Chevy C20 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2008, 05:01 PM
69ChevyC10's Avatar
American Muscle is King
76 Chevy C20
what transmission is in a 1976 Chevy Cheyenne 20 stock?
Old 12-17-2008, 05:11 PM
kookykrispy's Avatar
hot rod freak
A '76 C-20 would have either a turbo 400 Automatic or a SM465 (muncie 4 speed with granny low) if my memory serves me right...
Old 12-17-2008, 05:20 PM
69ChevyC10's Avatar
thank you very much for the quick reply
Old 12-19-2008, 08:06 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Agreed on both trannys.
Old 12-20-2008, 09:01 PM
My '75 K25 came stock with the TH-350, which surprised me when I first discovered it. I later on came across a web site that explained that the TH-350 was the right transmission for my truck, even though it was an 8200 GVW camper special.
Based on the info from http://www.chuckschevytruckpages.com/73-87specs.html the C-20 would also have a TH-350 in '76.
Bruce
Old 12-21-2008, 08:06 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I have seen, worked on, and owned, enough of this series of GM's trucks to know it could have been equipped from the factory with either the TH-350 or 400 for the automatic models, and the 3-on-the-tree Saginaw, OR the SM-465 for the manual transmissions.
Those four transmissions were the main ones available from 1973 to 1980, and the saginaw was the only one not used in 4WD. The others were in 1/2, 3/4 and 1 ton models, aside from the TH-350 not available in 1-ton the others were used widely across the truck line.
76 chevy to 52 front suspen thanatos General Rodding Tech 2 12-28-2006 09:44 AM
76 chevy blazer tranny question? 66 chevy truck Transmission - Rearend 20 12-06-2006 02:18 PM
Tach in 76 Chevy 1/2 Ton Phyrkrakr Interior 1 05-01-2003 04:34 AM
C20 Chevy Van (Circa 83/85) KevinG Transmission - Rearend 0 03-16-2003 09:31 AM
76 chevy transfer case purplePeopLEater Transmission - Rearend 5 12-15-2002 10:54 AM
