76 corvette 350/350 shift cable adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 05:22 PM
A little help please, Ive gone to u tube and a couple of other sites but im still perplexed on this shift cable adjustment thing. Both eng and tranny are out of the 76 vette. I have the original shift cable and an aftermarket bracket. Ive got the cable in the tranny and routed up to and pushed into the bracket. The long slotted hole is positioned on the carburator. I understand that as the accelerator is depressed it pulls open the detent. How do I adjust from here? bill
Old 06-25-2012, 05:32 PM
1971BB427's Avatar
Manually open the carb fully. Check the slot to ensure that the carb is not restricted by the end of the slot. At WOT you should be able to pull the kickdown cable and see it's got a little more left in that slot. Adjust so it does, and you should be good to go.
TH350 shift cable adjustment GUNTHER19820 Transmission - Rearend 2 12-04-2008 06:17 AM
T- 350 Kick Down cable adjustment? 49chevytruck Transmission - Rearend 4 07-31-2008 06:26 PM
350 Corvette engines,better than the regular 350's ( Myth or Reality? ) Calderone Engine 38 01-24-2008 05:05 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
TH 350 detent cable adjustment bildo95 Transmission - Rearend 1 03-29-2003 05:20 AM
