76 Corvette Brake Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 10:59 AM
I've replaced the master cylinder(twice), and all 4 calipers. I've bled the brakes, no air from anywhere. No leaks on floor under car. I can't get a pedal no matter what I try. Any ideas?
Old 05-15-2006, 11:13 AM
Did you replace the lines? Sounds like that's all you haven't tried. I have seen lines plug up completely and cause these troubles.
Old 05-15-2006, 11:17 AM
No, I haven't tried replacing lines. But it bleeds even on all sides. The booster doesn't hold vacuum, But I would imagine that should cause the pedal to be hard.
Old 05-15-2006, 02:15 PM
50 chevy p/u's Avatar
autoglass master tech
Did you bench bleed the master cylinder (s) before installing it?
Old 05-15-2006, 02:55 PM
Yeah. Both of them.
Old 05-15-2006, 03:10 PM
abstruse dutch uncle
On those cars I jack the back end of the car up a couple inces higher than the front, and tap on the calipers to help dislodge air bubbles while gravity bleeding. Raising the back levels the master and the calipers. I read it in a 'bleeding sequence' manual I have.
Let's see...
"Corvette, 1983-65,
LR inner, LR outer, RR inner, RR outer, LF, RF
Raise car to level master cylinder, tap calipers lightly to dislodge any air"
I've had best luck gravity bleeding or pressure bleeding them. When manual bleeding, I never let the pedal operator pump the pedal. Just push down and let up when I tell them to. I close the bleeder before they're done pushing and them have them let up.
EDIT
Oh, BTW, if the rotors are no longer riveted you have to fasten them down with a lug nut or they'll float around and you cant get a pedal.
Old 05-16-2006, 10:19 AM
Hey, Just thought I'd mention this. Wev'e seen this type of problem at
our shop. Make sure you check... Calipers installed with bleeders up top.
I know it sounds silly... pads binding in the slides.. Theses two can catch you of guard.
Mark
Brake Problem 35 buick40 Suspension - Brakes - Steering 7 02-06-2006 07:30 PM
1976 Corvette Parking Brake problem wrb Suspension - Brakes - Steering 7 10-01-2005 08:49 AM
1956 corvette disc brake conversion kparmenter Transmission - Rearend 3 10-30-2004 01:32 PM
Brake problem NEED HELP 74huggerorange Suspension - Brakes - Steering 7 02-27-2003 06:46 PM
69 corvette steering problem Suckingas Suspension - Brakes - Steering 2 12-26-2002 10:59 AM
