Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 76 f/bird window adj.
Old 07-02-2012, 11:16 PM
tech69 tech69 is offline
put up or shut up
Window stops. Not sure of the particular car but imagining two of them in the front and back. It's probably inside your door frame up high and bolts to the door frame. It will usually be just a simple piece of metal that stops it. Usually one bolt. Just take off your door panel and get a good look in there.
