-   -   76 f/bird window adj. (http://www.hotrodders.com/forum/76-f-bird-window-adj-221180.html)
f/bird 06-30-2012 09:40 PM
My power window on pass side trvels up to far with door in open pos. I have to close door then put window up . What exactly stops the window travel in the proper place ? Thanks
tech69 07-03-2012 12:16 AM
Window stops. Not sure of the particular car but imagining two of them in the front and back. It's probably inside your door frame up high and bolts to the door frame. It will usually be just a simple piece of metal that stops it. Usually one bolt. Just take off your door panel and get a good look in there.
