76 f/bird window adj. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2012, 08:40 PM
My power window on pass side trvels up to far with door in open pos. I have to close door then put window up . What exactly stops the window travel in the proper place ? Thanks
Old 07-02-2012, 11:16 PM
put up or shut up
Window stops. Not sure of the particular car but imagining two of them in the front and back. It's probably inside your door frame up high and bolts to the door frame. It will usually be just a simple piece of metal that stops it. Usually one bolt. Just take off your door panel and get a good look in there.
Building a bird cage for T-Bird 8.8 IRS oldskoolcoupes Suspension - Brakes - Steering 2 07-24-2011 03:48 PM
ADJ vacuum Modulator? Madmax305 Transmission - Rearend 2 11-22-2010 04:40 PM
coilover adj. HOTROD41 Suspension - Brakes - Steering 1 08-01-2009 12:20 PM
after adj valves mac350 Engine 6 11-07-2005 02:46 PM
Adj valve quartet Engine 0 11-02-2003 06:40 PM
