76 F350 truck small block v-8 RMS leak repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2011, 02:48 PM
fast68's Avatar
likes chevy trucks & boobies
76 F350 small block v-8 RMS leak repair
got my great uncles 76 or so ford F350 dually dump truck
it leaks oil from everywhere but the worst is a steady drip from the RMS
on the chevies 1985 and older you dont have to pull the transmission back to do these
what about these fords?
its a small v-8....
a 351 of some kind i imagine,
or whatever was in these with the 2 bbl motorcraft carb.
hope to god dont have to yank back the big *** 4 speed to do this.. hmm...
if so then whats gonna be a good trick to pulling it back and keeping it aligned straight?
bellhousing bolt studs to slide it back on ? or?
what size and thread?
thanks
Old 07-09-2011, 03:10 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
With a 76 yr engine, All you should have to do is drop the pan to get to the RMS. loosen up all the caps and remove the rear cap and let the crank drop down just enough to get in there and work and take it from there. JMO
If you have never done this before get a good manual and read up on it for they can be a little tricky going back in. IMHO Is it a 351w engine ?
IIRC 79 back are all 2-piece RMS and 80 up went to the 1 - piece seal.
Cole
Old 07-09-2011, 03:13 PM
fast68's Avatar
yeah no i dont need a book or whatever, trust me ive done LOTS of rms just not ford ones
i have a book for 1961 to 1971 trucks all makes i just had it for when i was 16 and stuff and was just starting out way back when and for the torque specs etc,.
i gues si coulda looked in there and found out what style RMS they used but this is a 76 and i dunno which v-8 except that its a sbf so,.,,
does it matter which one it is? are they all 2 piece regardless of which 351?
i dont know my old v8 fords i hate them all
the 240 and 300 sixes i love them and have owned some over the years
ive owned a full time repair shop since 1994
thats all i needed to know
thanks
Old 07-09-2011, 03:22 PM
eloc431962's Avatar
Wiki Edits: 37
351 ford
They all should be from 79 back a 2-piece seal. Not real sure on the exact year they went to the one piece thinking after 1980 though, do you know if it's the orginal engine ? and where you been anyway haven't seen you around much for a while now ?
Cole
chevy small block for truck pulling full pull bob Engine 4 08-19-2008 03:00 PM
78 caprice small block(oil leak) smurbs Engine 1 04-08-2008 09:22 AM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 04:02 PM
The right small block for a work truck Ugg Engine 1 06-30-2003 10:09 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
