76 GMC short bed 4x4 which tranny to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 07:53 PM
I have a 76 GMC short bed 4x4 with a built 350 out of a Vet, some are telling me to put a short shift kit in my manual tranny and others are telling me go with an automatic ???
Old 11-12-2012, 08:01 PM
Wiki Edits: 31
Depends on what you want. Short throw shifter doesn't even exist for the SM-465 your truck has. If it's an offroad rig, you probably like that really low 1st gear. If you don't like to shift, get an auto. That SM-465 will take just about any abuse you give it.
Old 11-12-2012, 08:09 PM
SSedan64's Avatar
X2^^ on above.
If you want an Auto, a 87-92/93 TH700R4 is a good choice.
Has a low 3.06 1st gear for take off + .70 OD/4th gear for MPG.
Trans-------1st Gear---2nd Gear----3rd Gear------4th Gear
TH700R4-----3.06-------1.62--------1.00----------0.70
4L80E--------2.43-------1.49--------1.00----------0.75
1941 Ford 2dr. Sedan/1984 GMC Short Bed nhcamper Introduce Yourself 3 12-18-2010 08:38 PM
1957 GMC Short Bed Truck with 1982 S10 Chassis? elias1693 Suspension - Brakes - Steering 1 11-14-2010 08:39 PM
my 1979 f150 short bed 4x4 fordisbetter Introduce Yourself 4 04-15-2008 03:31 AM
Making a short bed truck out of a long bed truck suggestions lon77 General Rodding Tech 8 11-22-2006 05:36 PM
can i put a short bed on a long bed frame? violent j Body - Exterior 9 06-07-2004 09:27 PM
