Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 76 monte drum to disc brake conversion?
Old 11-06-2012, 02:24 PM
angelf0926 angelf0926 is offline
I want to use wilwood two piston calipers..but the point is im not trying to spend so much on the conversion...if doable...i would rather remove the disc brakes from another car at the junk yard..then install my rotor, and caliper of choice
