Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 76 monte drum to disc brake conversion?
Old 11-06-2012, 01:31 PM
lmsport lmsport is offline
To use the Wilwood caliper will take either a kit from Wilwood or duplicating the bracket for the caliper yourself. Wilwood used to make some GM-style floating capliers. You can get a kit minus the capilers from a few places like SUmmit and Speedway
The rear disc from a 94-96 Impala SS will bolt on to your housing and uses the internal shoe parking brake.
