Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 76 monte drum to disc brake conversion?
Old 11-06-2012, 01:50 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Wilwood calipers require Wilwood brackets. The only way to duplicate the bracket is to have one to copy. You could just use a complete rear disc brake system from a 4th gen F body. They have good PBR calipers and you can buy cross drilled rotors for them. They also bolt to your housing ends.
