Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 76 monte drum to disc brake conversion?
  #19 (permalink)
Old 12-31-2012, 09:28 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The WS6 disc brakes were not available on the Camaro. They were Trans Am only and were only used on the '79 to '81 second gen cars. They had cast iron calipers and were not considered to be very good. There are much better options out there. 4th gen F body disc brakes are much better and will adapt to the Monte Carlo rear end. The F body second gen rear end wil not work in the Monte Carlo unles you use ladder bars or after market 4 link. It was comon for the '79 to '81 Trans Am to have 2.56 gears, which would make the differential a 2 series and only good for 2.56 and 2.41 gears.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
angelf0926 (01-01-2013), Crosley (05-10-2013)
