76 Monte whose "A_ _ is dragging - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2003, 08:34 AM
Talking 76 Monte whose "A_ _ is dragging
Hey Guys, I was wondering if someone could help me.
I have a 76 Monte Carlo, when I bought the car a year ago the rear end sagged. I put new rear Coil Springs and Shocks and this fixed the problem. By the end of summer the rear end was sinking again so I installed Air Shocks. This solved the sagging problem, but, now the car really rides rough and gets a little squirrelly on fast acceleration. Probably has to do with raising the normal center of gravity. Anyway, my question is :
If I put an “Air Lift 1000” system with the bags that go inside the coil springs will this solve the sag, rough ride and decreased traction problems? Thanks for the help.
Joe
Old 05-18-2003, 03:58 PM
sc3148's Avatar
Thumbs up
Yes this will fix it, airlift bags work on low pressure large cylinder design the opposite of air shocks, small cyl high pressure. This is why air shocks usually ruin ride!
Old 05-18-2003, 05:07 PM
Post
Are you sure you put NEW coil springs in the car, or were they new-to-the-car springs from another car?
Unless you're riding around with 300lbs, of manure in the trunk those new springs should have stayed just fine for years! Were they a brand name like MOOG or some weird Chinese AutoZone crap?
This just doesn't make sense....
Old 05-18-2003, 05:31 PM
Talking
pasadenahotrod,
They were brand new TRW Brand Coil Springs. After the new springs, the car did not sag as bad but the front end was still higher and made it a little difficult to see over the long hood.
No I don't have a trunk full of Manure LOL.
Joe
Old 05-18-2003, 07:57 PM
Post
Hey I was joking!
In all seriousness you should have returned the springs if they sagged within a year.
They should have raised the car to stock height. That is you should have been able to slide a hand in on top of the tire with your little finger laying on the tread and your index finger just touching the wheel opening moulding.
Old 05-18-2003, 11:45 PM
Post
If you use air bags/shocks, be sure the air hoses are connected independently of each other. If they are connected together, it will make the car handle strangely.
Old 05-19-2003, 03:14 AM
Don Meyer's Avatar
Post
Go to NAPA & get HD sprins...less than $100. The way you are going is expensive....Don
Old 05-19-2003, 12:04 PM
Talking
Thanks for all the help guys
Old 05-19-2003, 08:21 PM
Post
air shocks were the only fix that worked to get my '65 Caprice (Impala) to sit right. Two different sets of new, good brand, heavy duty springs both failed to get the back end off the grass. The ride is okay, in my opinion. I've never heard of these airlift 1000 gizmos but now i'm interested.
