76 pontiac 350 eng. fuel pump ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2012, 09:28 PM
I rebuilt 2brl. carb and reinstalled a couple days later and now I crank and crank and no gas comes out of the line . can I assume the f/pump is shot ? I have had some starting issues all along and was one of the reasons for the rebulid ,I can't get it running to adjust the carb now .
Old 07-17-2012, 01:28 AM
when i first fired up my pontiac i had to crank for a while to get the fuel back up. what u can do is have hook up the line that goes to your carb with a rubber line that goes to a funnel, put some gas in the funnel and have a buddy crank it while you hold the funnel up. if it fires up that way for a few minutes then u know at least the carb is ok. I did that to kinda prime the carb, once there was fuel in the carb the car was able to pull fuel up the line from the tank. thats just a suggestion. Im sure there are better safer ways.
Old 07-17-2012, 02:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unless the tank is empty or an inline filter or fuel line is totally clogged, the pump is shot.
Old 07-17-2012, 08:31 AM
I thought if it would't bring the gas to the carb after cranking it over for several sec.,or a min. or two ,it the (pump) wasn't very good or not at all ! I'll try to prime it if I have to take it in some place to get it done .
Old 07-17-2012, 01:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might get it to work by priming it, but after the fuel drains back out of the pump and lines- which is will if the valves aren't good- the prime will be lost all over again. My advice is to replace the pump and be done w/it.
Replacing the fuel pump on a Pontiac engine is not hard at all. If you have basic hand tools and a place to work, you can do it easily in an afternoon w/a Co-cola break or two thrown in for good measure.
If you think it's something you want to do, get back to us and we'll fill in the blanks.
4.3 Marine Eng To A 350 Chev Eng DAN CASPER Engine 2 07-19-2010 08:56 PM
1999 pontiac Montana fuel pump whatwouldscoobydo Engine 1 04-04-2008 03:17 PM
Pontiac 400 fuel pump yankeehonda Engine 6 04-13-2007 09:59 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-05-2006 12:56 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 10:40 PM
