Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '76 sbc build , need more head advice
Old 03-11-2008, 07:41 PM
TheCiscoKid TheCiscoKid is offline
Last journal entry: dash mods
warmed up the motor, starts well, runs smooth.Did compression test.Wired trottle open , 6 cylinders were 95-100lbs, one was 85, one was 75lbs.The gauge is Snapon so it's prob OK.Someone else did the tappet adjustments, if the lifters weren't pumped up and the tappets adjusted could the lifters now be taking the valve off the seats or are the heads toast/Or is my cam blowing it all out? thanks guys, Cisco
