Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 77 C10 stepside electrical problems
Old 12-04-2012, 08:24 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
I'm not an elictrianist by any means but, if you have bench tested your starter and it's fine, try running a seperate ground wire to your starter...bad grounds can cause strange events and everything else seems to be working. After you have your seperate ground wire run, and if it starts, try it several times to be sure.
Hope this works for you.
Ray
